What mount and servo
MJMARLOWE
Arizona
  2. Talion
Servo burned out in my 3s Senton with Granite tires.. does voltage hobbies servo most work on the 3s as well as the 6s.. also what servo? Thanks
I replaced mine with a JX 6221. I like it a lot and for $14 it's worth it. Only issue for you though is waiting to get it from China. Do a search on servos there is a lot of information that helped me pick. If you need something now and want to spend some money look at savox.
Will the savor 1210 or 1230 fit and what about a better mount like the voltage hobbies aluminum mount
You don't need something like a 1210 or 1230 in the 3s Senton.
No the Voltage Hobbies servo mount doesn't fit in the 3s Senton, nor does any other aftermarket part for any of the 6s models for that matter. There is nothing wrong with the stock servo mount on the 1/10 vehicles.
The Savox 0231MG would be more than enough for the 3s Senton. https://www.amainhobbies.com/savox-...etal-gear-digital-servo-sav-sw-0231mg/p262192
Put the Servo in that you suggested, however steering is reversed. How do I change it ?? Thanks
Use the switch on the back of the transmitter for steering rev.
