Do you run the 17T with the stock BLX system? Do you have any issues with heat?I run a 17t tekno kn the outcast and kraton and have never had a issue with it but I also run a rr pinion on my typhon sounds like your gear mesh was off not the opinions fault. Both are great quality pinions. Check you mesh out a piece of paper between the 2 gears press it till its crunched between. The 2 gears of your not sure how to mesh properly just a suggestion
