2.5 4x12 screw for the steering post iirc
Thank you very much!! Much appreciated2.5 4x12 screw for the steering post iirc
It's the same size as the one directly to the left of it.
Thank you, I just bought some Blue threadlocker. Have a good day!!^^^ yes same size as the other.
Remember to clean screw and use Blue TL every time it is removed. Best to use use some heat to hasten the removal if needed. Use a quality Hand hex driver set.
Ok, good to know! Thank you for your help.Looks like at the top or front you lost a screw to the bellhousing for the steering. One on each side as well as the screws you see up top... Normally where you find those damn 4 bushing that comes in the Ackerman or bellhousing.
At the bottom on my, Kraton it is empty as well there is nothing there so no loss.
