Thanks for your reply don't really want to remove the battery tray as don't want to upset the balance of the car. I'm not trying to build a speed run monster what kv would you recommend. just looking for a bit more power and lower temps then stock set up.Are you willing to turn the mount around and lose a battery tray? If so the 4070 would be a good choice. If not, then the 4050 is the max.
6S or 8S?Thanks for your reply don't really want to remove the battery tray as don't want to upset the balance of the car. I'm not trying to build a speed run monster what kv would you recommend. just looking for a bit more power and lower temps then stock set up.
6s6S or 8S?
