What solder do you use?
Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
Wienerslider, Germany
  1. Infraction
  2. Kraton EXB
I use this for the rc hobby and at work almost daily. I personally prefer having a small diameter like 0.6mm due to it melts quickly šŸ‘
Also adding flux to the wiring helps a lot
0.6mm is a bit slim for my own purposes. Soldering 8AWG into QS8s needs a lot of heat so I run my iron at 500Ā°C/932Ā°F and my 1mm solder partially just vaporizes on first contact.
Gordo
Northern N.J
  1. Felony
  2. Limitless
I did pick up some kester 63/37 0.61 and what a difference, I can solder now. I only drank 2 beers and was nice and relaxed. B4 with the silver bearing solder I would have slammed a 12 pack be pissed off, melted a few qs8,s, just be so down on myself wondering why I can solder wire connections. THANKS TO ALL for all your comments and recommendations.
TRIOXIN
Columbus Ohio
  1. Typhon 6s
Yeah I was just about to recommend Kester, been using the # 44 for years and have soldered thousands of joints with it doing electronics repair / projects / wiring, it's really good stuff. I prefer the 0.031 to 0.040 size. If you can't solder with the Kester, it's most definitely not the solder's fault. šŸ˜†
I've used both 60/40 and 63/37 Kester and both worked fantastic over the years and never had any issues.
