I actually bought the infuser below after hearing you recommend that tea infuser awhile back. I liked that everything was self contained within the jar. This combined with Naptha worked awesome. Too bad the Naptha didn't do much for the lithium grease I use on the gears but that isn't so bad to deal with.This you need.
A mason/ball jar with a lid.
A tea infuser https://express.google.com/u/0/prod...26OYj4Hr4QRcmGvQ4vVx-bD0wbqjJ7ORoC8HIQAvD_BwE
And Naphtha https://www.lowes.com/pd/crown-32-f...OvFU3gfycaQ-npTl-QB8yxvot8B6pOShoCkTwQAvD_BwE
Put diff parts inside tea infuser, put Naphtha in jar then stir tea infuser in jar. When done put lid on jar to store for later.
Dude that looks like it would work way better than the tea infuser.I actually bought the infuser below after hearing you recommend that tea infuser awhile back. I liked that everything was self contained within the jar. This combined with Naptha worked awesome. Too bad the Naptha didn't do much for the lithium grease I use on the gears but that isn't so bad to deal with.
https://www.amazon.com/gp/aw/d/B06WXXF81Q/ref=ppx_yo_mob_b_old_o0_img?ie=UTF8&psc=1
Just ordered one. Free 1 day shipping from Amazon. Thanks for this!I actually bought the infuser below after hearing you recommend that tea infuser awhile back. I liked that everything was self contained within the jar. This combined with Naptha worked awesome. Too bad the Naptha didn't do much for the lithium grease I use on the gears but that isn't so bad to deal with.
I second that. Acetone and a small mason jar for me.I drop all parts in a baby food jar, fill with one inch of acetone, soak for 5 minutes and then shake like hell..... as I remove and set out, I wire brush ( brass ) any remaining tidbits away. Take that infuser.......?
It does work pretty good and I got all of the gears, pins, cases and everything in there in one shot.Dude that looks like it would work way better than the tea infuser.
That was my thinking too. The only issue that I foresee long term is getting the crud out of the bottom of the jar. I'm thinking that if I get a second jar and slowly dump the Naptha off of the top that I should be able to save most of it.That is a great idea. Should make it less messy and able to reuse the same fluid for a long time. Thanks for the share!
