What successful builds can I make with these Arrma's
DetroitSlim
  2. Notorious
  3. Typhon 6s
Ok so I have a Outcast, Kraton and a Typhon all are 6s v3's. How can I best combine the parts to make a new vehicle or two out of them?
Here's a link to the @Thomas P YouTube page.https://www.youtube.com/channel/UCk2_aQr8TlaaiigrsBBxaDg If this guy can't inspire you to customize, no one can. Check out his threads here in the forum too. He has lots of pics showing his mods. @joostin420 also has some fully customized rigs. The forum https://www.arrmaforum.com/forums/rc-build-logs/ is a great place to get ideas too.
My 2 personal favorites are the kraton and outcast I just got my m2c build kraton finished she is a beast clocked it at 86mph and still have 1/4 throttle to give
If you stick the typhon hubs, axles, hexes, and wheels on the Kraton you basically have a Talion with slightly skinnier wheels.
If you swap in the front/rear differentials and differential pinion from the typhon into any of the other cars you should get slightly more top speed since it has more teeth with same toothed Spurs.
Fyi from what I've been able to tell the Outcast is basically the same main frame as the Typhon (meaning the shorter option) with the suspension/A-arms etc of the Kraton . So in theory you could make another outcast by putting the Kraton arms and such onto the Typhon.
Think and build it ;) So much inspiration comes from the members of the boards, internet searches, and YouTube. I am on a big kick with deanodizing aluminum parts thanx to @Thomas P
Check out some of my builds:
Kraton: https://www.arrmaforum.com/threads/anyone-running-tp-4070cm-2200kv-on-6s.5381/
Senton:
https://www.arrmaforum.com/threads/anyone-running-leopard-4092-1730kv-on-6s.7869/
Typhon:
https://www.arrmaforum.com/threads/anyone-running-tp-4050cm-3200kv-on-6s.10069/#post-134631
X-maxx (I know it’s not arrma):
https://www.rctalk.com/forum/threads/radioactive-x-bug-project.121450/
Senton:
Typhon:
NICE!
Senton:
Typhon:
[/QUOTE
What ESC did you go with that Kraton build?
If you’re willing to build from scratch with these parts, whatever you make, make it 4 wheel steering and send it and tell us how it reacts in the air. You have all the parts to do it....it would probably be the first of its kind....
Edit - I’m wondering if it would allow a controlled barrel roll....
