These? : https://www.prolineracing.com/produ...tires-mounted-12mm-blk-raid-2/PRO1012510.htmlYou should be able to swap the MX 28's as the Typhon has 17mm hex's already. Only issue may be the offset so hopefully someone will chime in that has tried them on the 3s Typhon as I've only ran them on my Granite and Bigrock.
This. I have the pre-mounted Pro-Line Trencher HP belted tires on my Typhon 3s. They come with a 6X30 hub, and you have to buy the 17mm hub separately. The Badlands come the same way. The offset works fine with a Typhon, but you may need to buy a deep 17mm wheel nut wrench: the wheel nut is pretty far in to the wheel. I would post a pic, but I can’t get to my pic files from this tablet.Proline MX28's or Proline Trenchers. Prolines require a 17mm hub adapter, but that's not a mod, it's just what's required to make them fit.
I wish mine did. I start a backflip off my ramp and it just lands upside down lol.Dude - my typhon 3s backflips with stock! I've had good results with duratrax six packs too.
That's what I'm gonna get today. ThanksProline MX28's or Proline Trenchers. Prolines require a 17mm hub adapter, but that's not a mod, it's just what's required to make them fit.
Yeah, I didn't recommend the F11 17mm rims because at one point they were discontinued. But it looks like Proline has re-introduced them (back-ordered right now). You can't buy them pre-mounted, but Proline also reintroduced the MX28's without rims, so you can buy them separately and glue them yourself.So, I'm not sure why these have not been recommended.. yes, they are discontinued through proline, but they still exist on eBay and the like...
Would the Backflip LPs (4S) fit ? Theyd seem like a sensible option ?You need BACKFLIPS...JK
