What would you do gensacearespammers ace bashing batteries?
John1982
So i bought 4 more gensacearespammers bashing batteries 8000mAh 4s to run in the Krayton.
Got home opened them and saw a different balance plug to my others. Realised id been sold bone smart batteries. Called the shop and they simply said as they had been opened nothing they will do. Seems these are old stock batteries as gensacearespammers don't make them, i never even knew from what ive read i thought all bashing batteries were G- Tech.
So i sent a email to gensacearespammers to see if they could help me and the shut the door well in my face.
I know i didnt buy directly from them but i would of thought they would of helped me a little?
Can you post a pic of the balance plug?
If your order does not specifically say g-tech or the sku of a g-tech lipo, then they owe you an exchange as they picked the wrong item.
If you ordered g-tech in error and got g-tech, Id hope they would accept a return...
gens-ace-r-spam the company isnt on the hook for anything unless the item is faulty.
All the smart lead is is a normal balance line with a data lead, it likely even plugs into a regular balance port. The voltages are still present along with a single data cable. What I don't know is if the leads are in order like a regular plug, or they did something silly like cell 1,3,2,4. And if that data lead will mess with another chargers voltage detection thinking its an extra cell or worse, series conning the full lipo voltage to some 5v circuitry . Or if removing that data lead inactivates the rest of the lipo. Im assuming someone has accidentally plugged one into a regular charger, or at the very least gens-ace-r-spam has a failsafe in place for that.
If I couldnt get an easy return, Id be testing the above and cutting that data cable or making my own balance lead.
Buddy, you can charge Gtech batteries with a non Gtech charger, and vice-versa. Did you even see if the plugs hookup? (Hint: they do and work totally fine).
Twice ive changed the tittle and txt in thread but it keeps going to gensacearspammers! WTF?
These were for my son to use ( with supervision from the wife) as i got him a 4s car, so i wanted the ease of plug it in and it just goes ahead on the d300.
I know i can charge them but i work away from home alot so he cant get his car out unless im there.
I bought them instore, drove arroumd an hour to get them and just asked for them so no leg to stand on.
Why cant i change the titel! Every time i tray to just write gensacearespammers on the title it turns into what you see! Whats that all about!
Do a search mate not just me
Why would the forum admins automatically replace the real company name you typed with 'gensacearspammers'? 🤔
Here you go
LOL @John1982 I didn't want to know the history, I don't care. If they go around spamming RC forums instead of paying for advertising, I want nothing to do with them. ;)
I don't have the exact story. I've read the story on here. But they made woodie upset & that was put into place. They are good batteries tho. I have several.
I'm trying to follow this since well I have a couple of g-tech batterys(one is the 8000mah basher battery) and a d300 to very reliably charge them. Are you saying the box says g-tech but it does not have the common black g-tech balance plug that the d300 understands? Or you bought a Gens_ace_branded battery that you expected to be the g-tech battery and is not? I would think is the pkg was mislabled the store should do something for you... if not well as stated, a d300 will charge any std battery assuming the balance plug is wired correctly. If that is a possibility then I have not seen it yet but then I still consider myself a rookie since so much has changed since I was a kid! Good luck in any case.
The bashing pro batteries have been non-gtech for a long time, I guess the newer ones are gtech, or at least some of them. But all of mine are non-Gtech.
