southcakk843
I have a 6s kraton and tired of breaking parts and the bank + I have two 3s line up arrma typhon n big rock they break the bank too..so I came up with the idea to try putting the 3s blx system in the kraton..jus bump the pinion gear up to a 19t from stock 16t cause no power is there but 19t is perfect…ran it once and it does great..motor jus needs a fan didn’t have temp gun on hand but I did the finger trick n it wasn’t bad but still needs fan!!! Tires I’m running are duratrax six pack glued on proline rims…smaller wheels from stock.. pretty much I have a deal breaker..jus enough speed power n not hurting my pocket…now battery time ain’t that long cus bigger car pulling l from a 3s system n battery is 5200 mah 80c…tell me y’all aspects about this??? Don’t care bout the negative comments/feed back aleast I made you take time out your day!! Thanks
