I like to use 2 3s packs reasons being if your 6s get damaged you have to replace it. If you damage one of the 2 3s packs it will be cheaper to replace. Second reason is I had 2 chargers that only charged up to 4s and I didn’t want to buy a new chargerI am going to buy a kraton v3 this weekend a d I'm wondering if I should get 1 6s or 2 3s lipos. Sounds easier to use 1 battery. Has anyone gone from one to another. Also any other tips when buying battery and charger. Thx
You have to keep in mind that the home power is at 110-120 volts while dc power is normally at 12v, so a 10 amp home circuit is good for 1100 watts and a 20 amp circuit is good for 2200 watts. So charging a 4s battery at 75 amps is about 1260 watts (4.2 volts per cell x 4 cells x 75 amps = 1260 watts). So the 75 amp charge of the 4s battery is about 11.5 amps on your home circuit.So this is a good site for safe charging numbers.
http://www.radiocontrolinfo.com/information/rc-calculators/rc-charger-wattage-calculator/#A
Enter in your battery specs, and it will let you know what is the proper charging rates for your battery. Now I have to question the 15c charge rate through. That’s 75 amps on a 5000 mAh battery. I’m not a expert, but that doesn’t sound right. A lot of home run a 100 amp box from their service drop, and bigger home run a 200 amp. Most electrical outlets are rated at 10-20 amps. Above that they trip the breaker. Most breakers are 10-20 amp. Again, not a expert...
Good to know. I know I've seen 15 amp and 20 amp but wasn't sure about 10 amp. I was just more pointing out that DC and AC are at different volts so when they say "amps" you need to do the math to figure out the wattage.Residential 120v wiring in the US is typically either 15a (white jacket) or 20a (yellow jacket). Pretty sure there is no such thing as a 10a circuit.
Regardless, a 15c charge rate is quite something and would work out to charge times well under 10 minutes even with balancing. What could go wrong?
