Wow thats sounds good to me ill try the stock 50t and buy a 46t after. I'll compress the springs as far down as they can go. I also put on the kraton wing looks more aerodynamic. Thanks mate appreciate your knowledge.If you’re running the hoons with the stock 50t spur you should be able to fit a 24t on the stock motor mount while still utilizing both top mount set screws. If you switch to the infraction 46t Spur you can fit a 27t pinion which should be good for around 81-83mph
Oh boy ?I stuck a limitless spool, hoons 27t in my notorious setup with 1650 KV MMX8s its just nuts but really fun but hitting a kerb at 75mph + on 8s is not
Front cvd and rear lower arm snapped but not surprisingly tbhView attachment 85485
Oh no??I stuck a limitless spool, hoons 27t in my notorious setup with 1650 KV MMX8s its just nuts but really fun but hitting a kerb at 75mph + on 8s is not
Thanks budI can put a 20t on my Typhon and Kraton 6s, but they are more stable platforms. I wouldn't put anything bigger than probably a 17t on a SWB like the Notorious or my Outcast personally. Be careful with the heat. I have dual fans and a heats sink from Power hobby since I also use this gearing for bashing ?
