talion newbie 248
- Talion
One question my charger keeps on saying current break what does that mean?1C is considered fast charging for NiMHs, so 1.6A. If it gets hot toward the end of the charge cycle, reduce current. If you're not in a hurry, use less current to get more cycles out of the pack...
Yes I do have it set to nihm charging.Do you have it set to NIMH charging? Also how are you hooking up the battery to the charger?
Excellent point @nino!Oooooor, check if the Rx and servo support up to 8.4V and go with a 2s lipo
Lol ok how bout this wayI don't believe so.
Where is the balance port?There's yer problem. You have to use the main port, not the balance port...
