Talion What's the purpose of adjusting the black servo saver nut?
Finfan88
When I grab front wheels off the ground there seems to be some slop at the servo shaft. Should I tighten this black nut? Is there a video to explain what adjustments do for steering?
That black nut as you put tightens or loosens the spring on the servo saver if it is to loose you'll notice your steering is not effective or not working at all.
I just put red locktite on mine last night. The blue gel loctite I was using seemed to work ok until I got it a bit wet yesterday, then it loosened up again. I cleaned off the blue with naptha, then screwed the nut up to the top of the threads, put a drop of red on the threads, then backed the nut down over it until about the middle of the threads which is where I had it before.
I have a savox 1210 servo though, so if you have a stock servo, you may want it set a bit softer.
