No time to google, but I remember that Mojave got longer chassis = bigger batterybayAssuming my Vorteks/Raider have the same battery bay; it fits easily in the battery tray?
Thx!
~s
Thx!
~s
Thx @MSgtVorteks/Fury/Granite and Raider all have the same battery bay, though the Raider has a shorter chassis. Our 2s 5000mah SPC batteries fit in all of them, but I needed to trim the foam blocks that come in them.
Does anyone use floureon batteries?........ If so what do you think of them?
Awesome..... I have 2 venom 2s 5000 mah 30c they are really good batteries but pricey also. Looking for something cheap but performs well.I bought one of these: Floureon LiPo
Liked it so much, I bought another.
Twenty solid minutes of bashing time and still has enough electrons to pop wheelies while rolling.
Im about to order this lipoBased on others recommendations I've picked up a couple SMC Racing 4S 6500mah 60C packs. They perform excellently on my Senton so thanks for the recommendation! Very nice (and inexpensive) batteries, would buy again!
I have that battery and it fits my Typhon. Same battery tray as I understand.Im about to order this LiPo
Do you know if this will fit on the talion?
Thanx
Floureons seem kind of hit and miss espescially if you read some of the Amazon reviews. Overall Smc or spc seem a lot better at only a slight bigger price.
When it blows up lol . No, a lot of them puff under normal use. More than the occasional bad oneHow do I know if I've got a "miss"?
You'll know by the voltages that you end up with if you have a poorly assembled pack or a bad cell. There isn't much leeway in what you should end up with, especially in variance between each cell. .How do I know if I've got a "miss"?
so if I hear what you are saying, I should be checking the voltage on each cell regularly, and if the disparity becomes high, discard the LiPo? Right now, they stay within 0.01~0.02.
Maybe, if you have the typical four button charger you should be ably to hit the third button to watch your cell voltages. If you are using an inexpensive clone charger those numbers might not be accurate though. I would get one of those small LiPo checker alarms to check against it.
https://sites.google.com/site/tjinguytech/charging-how-tos/LiPo-issues
Thanks @GT1 , so if I hear what you are saying, I should be checking the voltage on each cell regularly, and if the disparity becomes high, discard the LiPo? Right now, they stay within 0.01~0.02.
.01 to .02 volts is very decent after a full discharge. But the charger should always perfectly balance them again.
