6s outcast. It is still a great performer on 4s, so long as you bump the pinion a few teeth.Damn it! Still cant make up my mind. 4s kraton or 6s outcast?
I would say maybe, you can adjust the punch setting on the esc. I think it is set near the middle of the range iirc. The manual shows how to change it.I cant get my 4s outcast to do standing backflips stock out of the box. Is it possible to do standing backflips with the 4s outcast?
Just so you're aware, standing backflips are a great way to shred your drivetrain.I cant get my 4s outcast to do standing backflips stock out of the box. Is it possible to do standing backflips with the 4s outcast?
With my outcast 4s it was/is possible, untill I adjusted the slipperclutch and set it a bit looser. It is very hard to find the sweetspot again,.. to tight and it flips like crazy, to loose and the clutch will come loose again, even after locktite blue, maybe I will use the red locktite next time.I cant get my 4s outcast to do standing backflips stock out of the box. Is it possible to do standing backflips with the 4s outcast?
Have you cleaned your slipper screw and hubs? You may need to clean off the old loctite before using more.With my outcast 4s it was possible, untill I adjusted the slipperclutch and set it a bit looser. It is very hard to find the sweetspot again,.. to tight and it flips like crazy, to loose and the clutch will come loose again, even after locktite blue, maybe I will use the red locktite next time.
Btw..all with punch settings still on standard factory settings, and never broke a drivetrain yet.
Yes, with my outcast 4s it was possible, untill I adjusted the slipperclutch and set it a bit looser. It is very hard to find the sweetspot again,.. to tight and it flips like crazy, to loose and the clutch will come loose again, even after locktite blue, maybe I will usethe red locktite next time.I cant get my 4s outcast to do standing backflips stock out of the box. Is it possible to do standing backflips with the 4s outcast?
Everything new and cleaned, tommorow is the tesdrive..? thanksHave you cleaned your slipper screw and hubs? You may need to clean off the old loctite before using more.
Sand the slipper spring thats might be the cause of it loosening the slipperWith my outcast 4s it was/is possible, untill I adjusted the slipperclutch and set it a bit looser. It is very hard to find the sweetspot again,.. to tight and it flips like crazy, to loose and the clutch will come loose again, even after locktite blue, maybe I will use the red locktite next time.
Ok thanks I will try this when it is comming loose again, all ok for now after the testdrive.Sand the slipper spring thats might be the cause of it loosening the slipper
Just wanted to see what you guys think of the 4s line up.
Must really love them SWB wheelie machines! LolOutcast 4s...update, after 2 packs of 4s batteries the slipperclutch is still holding.
No loose ends this time. For me it was full tight on the clutch and back the bold out 3/4 turn, used blue locktite and let it sit for al least 24 hours.
Now saving to get a notorius..?
Is that 50mph on the stock 13t pinion gear?im so confused lol. on the one hand the 4s version i can reach 50mph and do stunts. no upgrades necessary. on the other hand the 6s is bigger more durable (some say lol) and not much slower. what should i do? lol
