Kraton Wheel bearings on the Kraton v4
Dakota
Are the stock bearings good bearings that can get wet for cleaning or will I need to get better ones ?
You want rubber shielded bearings. Stock are metal shielded and they don’t like water at all.
Will these work on the 2019 Kraton v4
Good set. When you open the pack, there are 4 really small bearings. Those are for the steering posts.
So these will work for the v4 ??
Yes. The changes on the V4 don't affect to many things. Difs, axles, suspension, and a host of other things remain the same.
Am I good to spray my duck off with water then luv all the spots that need it .. I don’t have an air chuck
Yes might want to spray moving parts with a non grease lub as not to attract dirt. Then wipe clean.
Yes, ducks love water!
But seriously, if you spray it off with water, use WD-40 on the bearings and other metal parts. After the WD-40 dries follow it with a dry lube spray as @Brandon said. WD-40 makes a dry lube that works pretty well.
I find Teflon based bike chain lube to be a good option for a lube as it is designed to stay on things that move and not to attract dirt.
Sorry about the spelling guys my phone auto corrects .. this is the spray I bought supposed to be good . So should I do wd 40 first then wipe off and spray with this . Or just use this ?
That is exactly what I was talking about.
Is it ok that I don’t have an air chuck .. just let it self dry or would a blow dryer be better than nothing
I would use the blow drier, anything to help get the water off of it.
Ok so the bearings in my v4 wheels should not get wet? So now I need.to get rubber bearings and buy a spray and grease for then after each run involving dirt/mud?
You can get them wet, just clean then off afterwards, dry them and use a dry lube. You shouldn't leave bearings wet for too long, even sealed ones.
Thanks so the rubber shielded just last linger were I to miss some water? I so have a compressor
Yes, the rubber seal keeps dirt out, so they last longer. The metal shielded stock bearings don't do a very good job if you ride it around in dirt or sand.
Buy them from Fast Eddy's: https://www.fasteddybearings.com/arrma-kraton-blx-sealed-bearing-kit/
(10) 8x16x5 - one in the outside of each wheel hub (4), 2 on the outside of the 3 diffs (6)
(2) 8x19x6 - one in the inside of the front and rear diff bulkhead (2)
(4) 15x21x4 - one in the inside of each wheel hub
(2) 5x11x4 - one on the outside of of the front and rear diff bulkhead (2)
(4) 6x10x3 - see below
These small bearings replace the bushings in the bellcrank and servo saver hub.
You will be removing these:
Two are found in the top and bottom of steering bellcrank:
The other two are in the top and bottom of the servo saver hub:
When you pull off the steering assembly, sometimes the bottom bushings will get stuck on the steering posts.
Hope this helps. And I will be honest with you. I use Fast Eddy rubber shielded bearings and I never clean them or even dry them with a compressor after I get them wet. They have lasted for months. I do check them periodically and just replace them when they feel gritty. As fas as actually seizing, I have had about 4 seize out of the 6 Arrma trucks that I run. Obviously drying them is a good thing. I am just too lazy.
You will be removing these: View attachment 35106
Thank you for this! I have a set on the way so this will be very helpful.
