Typhon Wheel hex extensions ?
HunterT
when changing factory wheel hex to TA hex extenders how do I remove the old hex? Do I need to just drive out pin or do I also need to take out hex inside of hub, I’m fairly new to this thanks!
Ok got it but the pin is not coming out easy? Am I missing something? Or just keep at it?
There is a grub screw inside the axle that holds the pin in. I think 2.5mm. Use a good hex wrench, and check to make sure the hex is not full of dirt.
Here is a screen shot of my V1 manual. It shows the screw. You don't need to take it all the way out, just loosen a half turn or so.
