Wheel Hex Nuts
Maxxwrecker07
IA
  1. BigRock
  2. Infraction
  3. Mojave 4s
  4. Mojave EXB
  5. Mojave Grom
  6. Notorious
  7. Typhon TLR
So there has been some discussion on the issue with wheel hex nuts coming loose. I may have found a solution! I ordered these:
http://www.ebay.com/itm/TEAM-LOSI-T...722725?hash=item543f263a25:g:a-QAAOxyYSdTBsJd
Not only are they a perfect fit, they don't come loose, they keep dirt out of the grub screw, and they keep the remaining threads on the hex clean as well. I also had a small issue with the original nut not threading on easily because of the Pro-line wheels I'm using. These have the flange that keep them squarely on the socket. The hexes themselves fit well too, but would require some shims to take up the space.
Hope this helps someone out! I love it when random parts "come together" ;)
Nuts from a kraton/talion/typhon do not come loose on the Nero. I like them better also. Wrench doesn't slip off as much.
