Wheel nut stuck
Jacob43
How do I get a wheel nut off. It seems to be cross threaded on my hub carrier.
Please help .
I got new tires I can’t put on do to stuck wheel nut.
I'd try drilling into the flat side of the nut to break it off the hex hub, but it's gonna be tricky with the plastic wheel behind it
Worse case you buy a new set of wheel hexes and just remove that one with the tire attached.
Please help .
Can you tell if the nut is cocked on the stub ? If it looks straight it could have just been over tightened. The nuts are serated so if it's over tightened it will require a good bit of force to loosen it.
What kind of tool did you use to try and remove it?
Try ratchet with 17mm socket
Watch this video about stripped wheels and tell me if you think your wheel is stripped
