Wheelie Bar Setting Talion
vetteman1000
Commack, NY
  1. Talion
I just received the Hot Racing Wheelie Bar in the mail and I am ready to install it. I saw there are three different height settings. I'm curious to know if anybody has set it at the highest and lowest settings to see which one is better. I switch into the speed gear and the Talion was uncontrollable. Immediately flipping backwards whenever I pulled the trigger the entire way in. Bought a 19T Pinion instead to adjust for this much power, but what is the proper angle. Higher or lower? All votes to be considered. Thank you for everybodies input.
Depends on how much wheelie time you want. Add higher diff fluid in the center to avoid wheelies.
A 19T pinion on stock motor? Buy a spare, it won't last long and die a horrible death due to heat, even fans won't help.
It will be fun though until it breaks.
