Wheelie bar settings?
Ole Fart51
Louisiana
  2. Talion
wheelie bars finally came for my two Nero's. Destroyed both bodies waiting for them. My question is, what setting do y'all find works best? I also removed the stock bushings for the wheels on the wheelie bar and installed bearings.
When I go in wheelie mode - the wide wheels provide the same stability both on and off road. To wheelie across a field is just so much fun. All my Arrmas get the full TBone treatment.
I used 5x10x4 sealed bearings. Takes two per side. Go to eBay and search 5x10x4 bearings. about 10 bucks for ten. These are the same bearings I replaced the steering bushings with on my Kraton.
My Arrma wheelie bar lasted 5 mins. First real cartwheel and I broke off a wheel. Thankfully Arrma will replace it when they get them back in stock.
What do you mean? Lego tires and foam. Curious
my 10 year old has a wall of legos we have pull out drawers - he's a lego freak. Well - these bad boys fit on the T Bones We have a HPI Flux Sprint 2 and tons of the 26mm wheels /tires and FOAM - cut some foam and glued them on
Dang! Hope that doesn't happen to me. Are the T-bone bars better?
How about that. For whatever reason I never noticed the wheelie bar was adjustable. I've been running it at the lowest setting (most forward screw), but it was a bit low. I've now raised it up one to the second hole. Seems like the right hight now.
I've been running the factory wheelie bar for months and it's survived much. It has great flexibility to avoid snags, and the wheels are nice. I prefer the snug look of it over the TBone which seems awfully large, but that's just a preference.
Nice tip on the bearings too. Thanks.
I have mine set on second to last hole. Like it so far.
Experiment dude ;)
Hmmm, I wonder if a complete RC could be made from Lego's....
Dose this bearings make any difference in steering?
So what would you guys say is the best wheelie bar to get for a nero, arrma or a different brand
The Arrma wheelie bar is the only one I know of that is adjustable. Because of that I think it's be the best one I have seen so far.
