Kraton Wheels for 6S Kraton
Finland1
What kind wheels and tires you are using for Kraton 6S
And where you got it ,, Proline ?
Dboots backflip from outcast/notorious all the way, readily Available from most places, a lot have had good luck with backflip lp's
Not so readily Available particularly here in the uk.
I am running backflips and copperheads. I like both and are great all around badger tires. The copperheads do have better traction so depending on your bash spot.
Pro line Trenchers 40 series on Amazon. Larger and more narrow then normal 3.8 trenchers and Kraton looks the best with them. Still would love if there was a 1/8 of the Rovan knob tires.... Not tire looks as amazing as tho's...
I preordered (they are always backordered which says to its popularity) the 4s outcast tires which are dboots backflips .. from all the info i heard read and seen they are the best all arounders .. a little smaller and lighter (better overall handling
check our resident basher @Rich Duperbash has some great comments and video
Thanks ,
We have run stock tires and I don’t like it because it goes balloons
