Bolshevikjoe
Just an old nerd playing with expensive toy trucks
- Williamsburg, Kentucky
- BigRock
- Granite
- Mojave
- Senton 3s
- Vendetta
I cannot describe to you the level of panic I experienced as a complete newb with a new (to me) BigRock that wasn't running right after a heavy front impact (bent the motor mounting plate as it turns out) when, whilst trying to pry the power module use with a screwdriver and just the right amount of profanity, I broke the 'pull here' tabs off of the module and just regretted all of my life decisions leading up to that moment. Ended up using the screwdriver as a chisel and hammering the power module loose. Ended up replacing the motor mount and went ahead and put in an upgraded spur and I'm still running the machine (sans tabs) today.Well yeah, the whole plastic unit that the motor is attached to. It houses the slipper assy. and pinion/spur gears.
Refer to your manual or Arrmas website for instructions. Seems you never opened it up before, if you have to ask? Get used to removing it. Where most issues arise from within.
Yeah it needs to be opened. Usually this is where you start. And where the problem usually lies, if it is not, then next you look over the front and rear diffs and driveline, with the P.M. still detached. The best way to detect any binding/ diff gear issues.
Moral of the story, watch a couple of youtube videos and bookmark the good ones and then have at it. You're gonna be alright, even if things don't go to plan. You'll get it figured out and if you don't, there's literally thousands of folks out here willing to help point you in the right direction. This whole community is pretty amazing in that respect.
