exactly what the title says. anyone know somewhere i can buy hot racing parts in the uk, can order them on ebay but its about £40 just to ship a chassis brace
Also scorched partsYou also have CRCU in the UK.. https://customrcupgrades.com
Yes the material is better, but the weakness is the screw going through the bottom of the chassis. My Hot Racing braces are 5 years old, I only replaced them this summer because I wanted black ones again instead of the de-anodized ones and the pressed in lock nuts were pretty much just nuts at this point. You will break or damage other parts long before you do damage to the chassis braces. To prove this theory I bought a set of $20ish dollar chassis braces off eBay. My only concern is that the holes do not go completely through the brace so if the screw shears off you are boned.Imo the crcu/m2c braces are far better than the hot racing ones.![]()
Braces of any make would be better if they were keyed like the talion/mojave to take the stress off the pin. Exactly why I drill mine out.Yes the material is better, but the weakness is the screw going through the bottom of the chassis. My Hot Racing braces are 5 years old, I only replaced them this summer because I wanted black ones again instead of the de-anodized ones and the pressed in lock nuts were pretty much just nuts at this point. You will break or damage other parts long before you do damage to the chassis braces. To prove this theory I bought a set of $20ish dollar chassis braces off eBay. My only concern is that the holes do not go completely through the brace so if the screw shears off you are boned.
https://www.ebay.com/itm/234540753040
Me too..Exactly why I drill mine out.
It’s less about that now because there’s other things I would like to get from HR mainly diff cases for a few of my cars and other stuffImo the crcu/m2c braces are far better than the hot racing ones.![]()
Each end should have 2 attachment points not 1. The rear really irks me as it makes the chassis brace essentially a lever instead of a brace.Braces of any make would be better if they were keyed like the talion/mojave to take the stress off the pin. Exactly why I drill mine out.
You mean like this...Each end should have 2 attachment points not 1. The rear really irks me as it makes the chassis brace essentially a lever instead of a brace.
+1Imo the crcu/m2c braces are far better than the hot racing ones.![]()
Agreed. Imo the rake of the brace and how far back the chassis mounting point is makes it a lever. The corally one is a far shallower angle going right up to the cd. Makes it far less likely to tweak the rear end. I also like how the bodyposts come off of the forward braces you mentioned.The front one is keyed with the steering top plated and Corally countered the rear wanting to be a lever by adding in the 2 braces that run forward from the rear. Traxxas also did their rear like that on the Sledge. The long wheelbase Arrma vehicles should have bracing like that imho.
Yeah it's pretty much useless at this point in time as I had mentioned the holes did not go all the way through the braces. I might buy another one and drill the holes all the way throughjust by nature of design renders that almost useless once that pin has sheared.
