Stock motor is a 5mm shaft. Mod 1 is also correct. If you use a larger motor it will most likely have an 8mm shaft. I get my pinions from Saga as well.Are you US based or other?
If US then Saga Custom gears would be my choice for gears: https://www.sagacustomrc.com/store/p90/5mm_Mod_1_Pinion_gears.html
Now I know the Kraton 8S motor uses Mod 1 gears and has a 5mm motor shaft but please check the above are suitable for your application before purchase as I am not familiar with the Kraton 8S as I don't own one. @bicketybam will hopefully confirm or point you in the right direction if I am wrong.
Thanks for the help, much appreciatedStock motor is a 5mm shaft. Mod 1 is also correct. If you use a larger motor it will most likely have an 8mm shaft. I get my pinions from Saga as well.
