I just recently tried some Zeees, seem to be decent cheap lipos. Pretty sure you can get them with EC5s. You can buy them on Amazon, Ebay, or from the Zeee Store direct.thanks
I like those as well as gensacearespammers. It needs to be ic5 compatible though because I don’t want to run any adapter. thanks
I finally have a good charger so I want to buy a powerful high quality battery because I can now take proper care of it. thanks
turnigy heavy duty 6s 4000 mah 60c been good and durable for the price. I use in the talion loads of powerWhat 6s lipo battery do you guys recommend because I want to run a single lipo in my 6s typhon? thanks
Solder on some connectors so you wont be limited in selection. One option. Yes stay away from adapters between the ESC and Lipo. For charging it is fine.thanks
Can I raise the rear body mounts on the 6s typhon to accommodate the 3s 5000ma spektrum hard case batteries I already have so I can run 6s? thanksI'm currently running the Spektrum smart battery setup recommended by Arrma and I'm loving it so far. Super punchy!!! I run 2 of the 5000mah 50c 3S hard case lipo's (They have a single 6S as well). Only issue was I had to raise the back body mounts for it to fit. But simple to dorear
AgreedDon't buy VENOM LIPOS overpriced dog SH*T
