So 20k is better then 10k in big rock?10k silicone fluid is stock. No need to have really thick imho 20k should help reduce diffing out. Too thick and it will make the steering feel sluggish
I wouldn't say it was better, but I used to find one front wheel would balloon like crazy, which affected the handling. 20k solved that issue, but now has a bit more understeerSo 20k is better then 10k in big rock?
Use same front & back?
Same oil front & back?I wouldn't say it was better, but I used to find one front wheel would balloon like crazy, which affected the handling. 20k solved that issue, but now has a bit more understeer
I've got thicker in the front. Helps to pull the front straight out of turns, hence it can be a bit understeer'y.Same oil front & back?
Hey guys I have a few questions:
1. Just ordered 2 diff from JennysRC. Will they have diff fluid in them?
2. Front diff was locking up. The posts inside(pic attatched) the inset ones are wobbly. Bad?
3. The big gear in there looks like its outer edges were worn. To me. You think?
4. Anything I should do b4 installing the new diffs to prevent quick diff death?
Thank you.
Super newb!
Oops. The 2 that end up being shorter are easily moved. Seems like it would make them bind
Yes, loosen your slipper about 1.5 full turns.4. Anything I should do b4 installing the new diffs to prevent quick diff death?
Pretty sure I hit the nail that time. After putting it on a easy spin pin. Homemade contraption. With light behind it. B4 and After I sanded all way around it looked warped. Gonna put a thread out tonight after work. I believe it may have got a little too hot in my car or work van. And warped diff things. I just don't know what all it could be. And. Need a fresh thread so I can keep up with everyones thoughts. Thanks manI use 50kf/30k rear for my Granite and Typhon. If I had a BR I would do the same lol
Those pins are only loose when there is nothing attached to them. Once you add the gears and close up the diff, give it some turns and just make sure there isn't binding. The gears themselves are actually pretty decent and usually don't fail. What WILL fail inside those cups is the plastic seat that the higher pins/gears rest into. Those can crack and you'll know right away that something is wrong because it will be a very audible sound coming from the diff
Hard to tell from the pic but the input gear looks OK? Once you put the diff back together and tighten the yoke down you shouldn't be getting much binding. I have found that there is always a rough spot in one spot when you turn the gears and once you run it the plastic will wear in and that binding usually goes away. If for some reason you install new gearing and tighten down the yoke and you can hardly turn the gears, more than likely your yoke is warped in some say and needs to be replaced. No amount of shimming will help trust me lol
