Which type of heat is better?
Close Enough
Kraton 6s
Great information out there everyone. Sort of new to this hobby but having a great time with my v3 kraton. As far as breaking down the thread locker on metal to metal connections, which type of heat works better, a torch or soldering pen? I’m prepping for some bigger tear-down projects.
jondilly1974
Speed running rookie, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
I could see the benefit of both. Do you guys reapply loctite to those screws when they go back in?
I generally use a blue TL stick for small screws. I will use red on pinions or other parts that I can heat to remove. I have also resorted to red on parts that won’t stay together with proper applications of blue.
jkflow
Tampa, FL
Kraton 6s, Talion
Torch works best imho. Soldering iron should be 80W, same I use for soldering power wires. Torch is typically quicker.
Small butane torch, not the flamethrower :p
olds97_lss
Bash Break Repeat!
Dekalb, IL
Due to location. I use butane torch where I can and a soldering iron where I have to.
Same. I started using orange locktite instead of red. Seems to be a good compromise on things you want to stay put. If it's a 2.5-4mm head screw, if the head is good and the screwdriver is good, it will break loose when you lean on it. I still only use blue on 2mm button/flat head screws... unless it's a diff or diff input cup. Then I use red and a torch. The orange seems to be holding well on my pinions and a few other things I've used it on so far.
Canada 🇨🇦 Montreal
Kraton 4s
For me my soldering iron did nothing i was able to touch the screw with my hand without burning myself so since then i use a lighter i make sure to be close to the blue flame to avoid my part to become black
Maybe my soldering iron is junk idk
jondilly1974
Toledo, OH
Usually it’s the tip that can’t transfer enough. You need a chisel tip and hold it on the screw for 5 mins.
