Kaydenze23
New Member
- Granite
- Voltage
Hello we were out driving my daughters new arrma granite voltage this afternoon and all of a sudden it started whining but not moving. Anyone know the issue? Thanks
Thank you. Ended up taking it all apart and finding the diff outdrive was strippedSounds like the Pinion gear came loose. If so that should be an easy fix. If the Spur is stripped that will need to be replaced.
