- BigRock
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Mojave
- Mojave EXB
- Nero
- Notorious
- Outcast 8s
- Outcast 6s
- Senton 6s
- Talion
My list, in order, is the BRCC, Senton 3S, Redcat MT10E, Redcat camo TT, Granite 3S, Redcat Terromoto V2, Tenacity SCT (i just picked up a roller of this truck, but im building that strictly for racing), and, possibly, another Team Associated.
I have 2 Redcat TRMT10s. The main problem with them is that the motor has no overhead. The 4000kv is too high for the car & the 9t pinion leaves the car slow, 40ish on 3s. A lower kv motor would have more torque & more pinion options. I switch out one for a 3300kv & a 17t pinion. It flies on 3s. But I couldn't stop there. I put a 4s system in the other & it's ballistic. I wish it could take a larger motor since the 4s 3660 can get pretty warm but I recently put the huge Arrma heatsink on it & it has made a drastic difference. I had to put beefier links on both trucks. The stock links snap if you roll into anything larger than a golf ball. Also the center diff upgrade is a must. I wrecked a rear diff on my first run with the stock spool & I sat both of them until I did the upgrade. I had no diff problems since. The surprise of the car was how good the tires are. They are just as good as the Granite tires & share the same 14mm hex.
I either own or driven most of the cars you've listed. The Camo & Terromoto are nightmares. Weak everything . . . if they were $100 cheaper they still wouldn't worth it. Save yourself the headache. Both cars feel like they were assembled in sweatshops.
