parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Got a Losi Lasernut U4. I do not want to use the stock wheels due to known hex issues.
I am asking for wheels to buy in another post but at the same time looking for 2.2/3.0 wheels. The question I have: Why could I not use this lightweight wheel marketed for the drag racing market below? I am not jumping but bashing my Lasernut.
SSD RC 5 Hole Lightweight Aluminum Drag Racing Beadlock Wheels (Silver) (2) (2.2/3.0")
Specifications:
Wheel Width: 44mm
Tire Bead Width: 39.5mm
Offset: 1.9mm
Backspacing: 23.6mm
Weight: 89g (with hardware)
12mm hex
The Lasernut stock tire specs are:
Wheel Offset: 2.0 mm
OEM Wheels and Tire: 236 grams - 146mm tall / 57mm wide
At the most, I am off .1mm on the offset, which I could make up with Vanquish Products SLW Hex Hub Set, so I was told. But, I might not need to do SLW not sure.
The stock wheels are plastic, and the issue is the plastic hex destroys under-usage. Although this is a lightweight wheel, It still has to be more durable than a plastic wheel. The rim is light so with 4 or 5 (one on the back, maybe) lowers the tire weight....maybe beadlock tire weight should not be a concern with the Lasernut for me...
I plan to install Proline Hyrax U4 2.2/3.0 rock tire on those rims. For other rims I have looked at for 2.2/3.0 each average wheel weight is about: 4.45oz / 126g
My concern with all is it says "lightweight," but compared to stock plastic, I do not feel this is an issue for a basher rim. Do you?
Specifications:
Wheel Width: 44mm
Offset: 1.9mm
Backspacing: 23.6mm
12mm hex
