Senton whos got the fastest senton??????
K-BASH
ST.LOUIS
  1. BigRock 4x4
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Senton 3s
  6. Typhon 6s
if ya have a senton you now what parachuting is. Air under body an lift usely nose up bout 60ish then slams down hard.planned on speedrunning notorious today.so set senton6 up for speed..went 78mph with this body I cut up a bit on lighter 1/10 senton. Time to try it on s6.bl150 quikrun, 28/46 gearing,little bitty tp4030-2070kv, ran motor 1 time for couple minutes.,see what happens.did some red-neck engineering on it.lmao...this was my 1st arrma,,senton blx 3s 4×4.🤙🤙
almost forgot..@MFM where you at???time to get that shelf queen out let's see what sees got.
With my Senton 6s V3 on stock electronics with 20t pinion , hoons ,300k cent diff , sway bars , lowered , stock body , got 63-64 out of it . To tell you the truth , it seemed faster than what my gps said, it came by like a bullit .
I think it was 290 thou.ole jd has been quiet over winter.i bet he's gonna come this spring guns blazing.they say he hibernates like a bear
@MFM
In this vid it said 62 , next day fresh batteries , did not video it , but got 64 . Once they discontinued it ( was still new in box ) orig tires came off right away , and never drove in dirt /grass etc . Only street now , this is fast enough for me .
K-BASH, yer senton body looks like it's breaking up on re-entry! Love it!
They look to be similar wheelbase, combine yer expertise and build one chassis to end them all, swap a few bits to suit the bodies and go school everyone! 3 in 1 kinda deal.
I'm really wanting a 1/5 car but have been stuck between Losi DBXL-E 2.0 and Kraton 8s (EXB? maybe)
Losi to me looks way better but aftermarket support seems lacking which makes the choice incredibly hard even with the heavy discounts going around on them.
What abt me? I use to have a senton but I converted it to a Typhon. My PB is 106mph. @K-BASH, I got the custom spur gear done. Just a bit of sanding to finish it off the were good!
106 in Senton form or Typhon setup ?
@K-BASH im gearing up bro but weather is no good still.
I’m running vanguard 2200kv w spektrum 150a esc. Geared 20/46. So far this is all I’ve been able to achieve before taking flight.
U got a mean ass motor in that thing don’t ya
Swb or stretched?
Typhon form. It's impossible to get over 65-85 with a senton body
Not if body is cut up an fastened down well.this senton weights bout 3lbs more than yours.center diff puts power down way better than slipper clutch
Swb or stretched?
Swb ..swb is lot harder to control.imo lil ole 40×67 tp4030-2070kv an h-wing 150a.she got more ,but I need to aligh & tight steering up.i crashed it hard 3 times.broken body post a scratch is it
Heres a screaming pass from yesterdaywith noto..gnss said 92..but when I compare to other runs it looks an sounds way fastest.trying to beat 101mph pb.
