Wow! That seems like it almost split in half? Was it leaking?A rock got it there and eventually made its way back out, but not before leaving its mark. It happens from time to time
Those hr cups suck i had 3 on all my diffs they wear out fast and bearings also like to get stuck on them i like the stock ones lol until someone comes out with a better aluminum one.Good news is, it's a cheap plastic cup. What if it was one of those nice HR aluminum cups? Scarrrrry
Uh oh. I bought two for centers only. I'll keep an eye on those bearings, but I probably don't run as much as most people. I'll take em out every four or five runs or so, and clean and re-oil them. Gonna have one dedicated to 200k and one to 500k. Fingers crossed.Those hr cups suck i had 3 on all my diffs they wear out fast and bearings also like to get stuck on them i like the stock ones lol until someone comes out with a better aluminum one.
I have the hr cups in all 3x diffs in my Kraton and senton builds. Going the same route with typhon gt8 conversion. They have held up great in my Kraton with the power of the tp 4070cm 2200kv motor. I know if I did not run the hr cups the diffs would have grenaded. Going to tear down and do maintenance soon and will post pics. Sorry you had bad luck with yours.Those hr cups suck i had 3 on all my diffs they wear out fast and bearings also like to get stuck on them i like the stock ones lol until someone comes out with a better aluminum one.
Yeah all 3 of mine wore out where the pin sits i even had a shim on between to reduce wear seems the aluminum is very soft so it eats up the o ring and you can no longer fit another in thereI have the hr cups in all 3x diffs in my Kraton and senton builds. Going the same route with typhon gt8 conversion. They have held up great in my Kraton with the power of the tp 4070cm 2200kv motor. I know if I did not run the hr cups the diffs would have grenaded. Going to tear down and do maintenance soon and will post pics. Sorry you had bad luck with yours.
Not having a steel insert for the output shaft end, I could see that as an issue. Nova used to make diffs for the savage/tmaxx/revo out of 7075 aluminum which was harder and held up better.Yeah all 3 of mine wore out where the pin sits i even had a shim on between to reduce wear seems the aluminum is very soft so it eats up the o ring and you can no longer fit another in there
That would be nice if they added the steel insert kinda like the arrma diff cups except aluminum i really liked the hr diff cups but not the way wear out so fast.Not having a steel insert for the output shaft end, I could see that as an issue. Nova used to make diffs for the savage/tmaxx/revo out of 7075 aluminum which was harder and held up better.
Surprised there aren't any diff cases that are a 2 piece design with the steel end cap and aluminum circle for the cup part. OFNA used to make some, but they didn't have steel inserts for the X pins I don't think.
I didn't have a problem with the center diff bearings only the front and rear i think from the impacts it smashes the outdrive into the cup and flattens the aluminum around the bearing so it makes it really difficult to remove the bearing without damaging itUh oh. I bought two for centers only. I'll keep an eye on those bearings, but I probably don't run as much as most people. I'll take em out every four or five runs or so, and clean and re-oil them. Gonna have one dedicated to 200k and one to 500k. Fingers crossed.
