Talion Why does talion turn sharper to the right than the left... Please help
Finfan88
Servo is centered... I tightened the servo saver nut... Set my steering end points... Steering assembly seems to have not alot of slop... Im stumped. Off the ground when I turn wheel left and right real fast with my savox 1210sg it's fine, but when I slowly turn to the left it doesn't reach the maximum turn... turning right if fine. Please post replys... Thanks
You are running the 1210? Are you pushing 6V or 7.4V to it? I know the mechanical advantage isn’t the same between the right and left side based on the lever arm so it would turn easier one way Over the other especially if pushing 6V.
The only thing I can think of there's a 5 sided nut on the steering akerman on both sides. Do I have to tighten that nut down or should it be semi tight to allow it to rotate along with the akerman going back and forth?
Talking bout the big black bolt or nut in this picture.
My first test would be to disconnect the servo from the steering and make sure that nothing in the steering system is binding.
