Rubber band sounds like a good idea.I think that will help.thanks man .I recently had the same problem with my Granite. It's because the wire is moving around too much and tugging at the connection. In my case it was likely due to the battery straps coming loose and the battery popping out too often. I got the 6s battery straps. They're thinner, but they hold stronger because they're longer and they're hook on one side, loop on the other. The 3s/4s battery straps use a weaker hybrid style velcro. I also reversed the battery strap so I can run the velcro over the top and sides of the battery. No more battery pop out.
Since the straps are longer and more secure, I can also hold the esc/battery wires with them. The shorter/weaker 3s straps lose too much grip if you run the esc/battery wires under them. Finally I also have a thick rubber band around the middle of the battery to prevent any back and forth sliding of the battery wire. With two battery straps and a rubber band holding the wire, it can't move around anymore.
I actually just ripped out my second ESC wire in no time. I used just the rubber band for many months with my first ESC, so it may still be a good idea. But don't completely strap down the ESC wire like I advised in this thread earlier. I think I got 5 runs before the wire snapped this time.Rubber band sounds like a good idea.I think that will help.thanks man .
Have you put in a warranty claim? Horizon Hobby is sending me a new ESC under warranty. They replaced both my ESC's. Plus, they got back to my email in one day this time! Very happy with the customer service.Ok so it will still work?
I'm always worried about stuff getting caught up in the drivetrain, but yeah, looks like I need to leave lots of play.
sucks big timePlay is what leads to failure. Immobilizing the capacitor board with respect to the ESC is key. In any industry other than RC, soldering is prohibited in seismic environments - any flex at the solder joint will lead to mechanical failure of the wire. The heatshrink does a good enough job of immobilizing the wire going to the battery, but not the wire going to the ESC. The wire is designed to fail at the ESC side of the inline capacitor board:
I really wish the RC industry would just figure out how to use crimps.
USAre you the UK bro?
OMG another ESC wire snapped, same place. My first one lasted months, somehow the wire shredded, but the solder joint stayed intact. These last 2, the solder joint failed after a few runs in the same exact place.
