RC Panther
- 4x4-Mega
- Granite
- Kraton 6s
Thanks
Thanks Brother I will try this but Jenny’s rc is sold out of about 95% of her products, do you have another vendor you can refer?Did you reuse the front and rear ring and pinion on the difs? The ring gets a slight hard to see wear. Look for a couple teeth that are shorter, use a magnifier. This is almost always the problem.
I usually just buy complete difs assembled with housings. By the time you get the ring and input gears bought for just a few dollars you can get the whole thing from Jenny’s rc.
How did the gear box changout fix the issue?, was there a small crack of some sort because I just ordered all new inside & out gear kits and will upgrade to a aluminum gearbox front and rear from HR or GPM if this will solve the issue. Taking the rig down over and over with no positive results has pissed me off but fun just not always time to do this and like a Range Rover I don't want to have to buy two so I can drive one while ones is always down I may move to a Traxxas rig. Because I'm new I took the advice of my friends telling me to go with Arrma projects but I have had nothing but issues with this Kraton and I've already dumped way to much money is parts with no fun time driving this. Any advise will help because Friday this baby goes on Craigslist.I had EXACTLY the same issue- no visible wear. Real pain in the but honestly. Because I’ve removed the entire bulkhead to correct the issue. Ended up swapping in a new complete gearbox case from Jenny’s RC and it cured the issue. Literally NOTHING else I did helped. I need to buy two new ring gears and the input gear. Thanks fully diffs are GTG still. Good luck- was mildly infuriating.
I wont lead you to this issue because you seem like an awesome dude LOL!, I did shim the internal gear set as well and the issues remain. One mans trash is another mans treasure lmao!Add a shim to the input gear on the inside of the diff. These shims are harder to find due to size. Cured my slip issues.
If you want to throw it away throw it my way or tell me where your trashcan is located
That's the little gear in the pic but shim on the inside of the diff is needed.
Hey @RC Panther, eBay kit breaker would be the best bet if Jenny’s is out. There’s usually a few whole assemblies for around $35 or so. https://www.ebay.com/sch/i.html?_fr...aton+d.TRS0&_nkw=kraton+differential&_sacat=0Thanks Brother I will try this but Jenny’s rc is sold out of about 95% of her products, do you have another vendor you can refer?
Thanks again!
Panther
