Well I should have used a little more loctite! truck does have a lot of hours on it. Scheduled to get torn down this off season.
Well I should have used a little more loctite! truck does have a lot of hours on it. Scheduled to get torn down this off season. View attachment 283423
One of the screw that holds the 50t to the center diff backed out digging into the motor mount. I used more loctite this time.I had this happen on my 6S rigs as well.
Option one I went to M5 pinion so the grub screw is a lot bigger for more contact for loctite
https://www.amainhobbies.com/tekno-rc-m5-hardened-steel-mod1-pinion-gear-w-5mm-bore-13t-tkr4173/p454501?v=211307&utm_source=transactional_email&utm_medium=e-mail&utm_campaign=order_complete&utm_cid=4109717&utm_content=/tekno-rc-m5-hardened-steel-mod1-pinion-gear-w-5mm-bore-13t-tkr4173/p211307
Another option I bought better grub screws with a flatter contact to the motor shaft
https://www.amazon.com/gp/product/B0828F5F1T/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
