Widenin my limitless
EvilChico69
New Member
Hey guys im fairly nes to the modern rc and just bought a limitless and corvette body. My question is how can i widen the wheelbase. I don't need much but unsure whether i should fit extended hexs or just buy offset wheels. Also any suggestions where to get them wud be appreciated. Thanks
StephenSchandelmayer
Rig of the Month Winner
Florida
  1. Limitless
  3. Kraton 4s
  4. Outcast 8s
  5. Typhon 6s
Just bash it RC makes extenders in a few different sizes. You can get other ones on ebay for much less. The JBI ones are good quality but the ebay ones have worked for me in the past as well, I took a set of eBay 30mm extenders over 100mph many times and had no issues.
M2C racing makes a couple sizes too but not as wide as JBI or eBay. Just depends what you need
dure16
Illinois
  1. Fireteam
  2. Granite
  3. Infraction
  4. Limitless
  5. Kraton EXB
  6. Outcast 8s
  7. Typhon 3s
  8. Typhon TLR
Powerhobby makes a wider tire with the same 100mm diameter. I don’t know if they’re any good but that might be another option for you.
Power Hobbies Powerhobby 1/8 Gripper 54/100 Belted Mounted Rear Tires/Wheels 17mm (2) Arrma Felony/Infraction/Limiitless (Black) https://a.co/d/5IT0N7f
Moirae
Beauty & Beast
  1. Felony
  2. Fireteam
  3. Infraction
  4. Limitless
  5. Kraton 8S
  6. Kraton EXB
  7. Kraton 4s
  8. Mojave EXB
  9. Notorious
  10. Outcast 8s
  11. Outcast EXB
  12. Talion EXB
  13. Typhon 3s
  14. Typhon 6s
  15. Typhon TLR
Gpm makes +13mm extensions for cheap and they're on ebay. I use them on my limitless to make rear wheels fit the jota body.
fozzy71
Michigan
  1. Fireteam
  2. Infraction
  3. Typhon 6s
  4. Vendetta
It looks like there are a number of options from Hot Racing and other China companies (but none from GPM?) on AMZ when I search 'gpm 17mm hex 13mm extension'. I have never had a reason to try any myself yet.
A follow-up question from another Arrma newb: The OP could also 'truggify' it with Kraton hubs, blocks, stubs, and hexes like I am about to do to one of my Typhons, couldn't he? It would obviously be more expensive and more permanent but I am curious in case I ever decide I want to widen my Infraction.
Diem Turner
Yes...I have a Premium Member
Wienerslider, Germany
  1. Infraction
  2. Kraton EXB
Sorry to be pedantic (I'm lying...I'm not actually sorry because this is who I am) but you don't widen your wheelbase, you lengthen or shorten it. You can widen your track width. Yes, I know that's what you meant but...it's never too late to start using the correct terms :)
The +13mm GPM wheel hubs that @Moirae mentioned are a cheap and easy way to widen your car. Can recommend (y)
Moirae
Beauty & Beast
  1. Felony
  2. Fireteam
  3. Infraction
  4. Limitless
  5. Kraton 8S
  6. Kraton EXB
  7. Kraton 4s
  8. Mojave EXB
  9. Notorious
  10. Outcast 8s
  11. Outcast EXB
  12. Talion EXB
  13. Typhon 3s
  14. Typhon 6s
  15. Typhon TLR
Sorry to be pedantic (I lying...I'm not actually sorry because this is who I am) but you don't widen your wheelbase, you lengthen or shorten it. You can widen your track width. Yes, I know that's what you meant but...it's never too late to start using the correct terms :)
Learn something new every day! I didn't know that either. :ROFLMAO: :ROFLMAO:
@fozzy71
https://www.ebay.com/itm/193461423100
