Tried to fit the 4s pinion on a 3s one and it didn't work will the 3s work on a 4s motor?
The Kraton safe-d5 pinion didn't fit on my v1 Sentons motor. I'm buying a kraton motor and I have some 3s motor pinions from the new Senton will they fit?Are you mixing shaft sizes with Arrma's SAFE-D pinions? Generally the brushless motors in this category should be 5mm shaft size but may or may not be SAFE-D compatible if the flat is not cut all the way down the shaft.
My motor was v1 so I think that was my problemIf you’re talking about current gen cars, then yes, the pinions should be interchangeable.
The new kraton motor at jennyrc.comWhat motor are you buying? Do you have a link to it?
