Country Boy
I hear they have the same length chassis but are the body posts the same? Could you effectively throw on the body and some MT tyres ?
Cheers for that, very helpful. Looks doable without too much hassle.I stopped everything I was doing just to check for you. And we were just about to find out if this guy is the father! Looks like if you take off the side guards and use the BR mounts it will work but I'm not sure. Body posts are definitely different. So final answer is need BR posts and sideguards you should be otherwise ok. Hopefully someone that's done it weighs in.
Side by side so you can compare the mounts.
Switch the big rock body post out with the senton..if you haven’t tried that.. mite have to do some trimming go the bottom of the post but should work.just swap body postI stopped everything I was doing just to check for you. And we were just about to find out if this guy is the father! Looks like if you take off the side guards and use the BR mounts it will work but I'm not sure. Body posts are definitely different. So final answer is need BR posts and sideguards you should be otherwise ok. Hopefully someone that's done it weighs in.
