Vorteks Will Badlands rub on a Vortex?
99Trey
  1. Typhon 6s
  2. Vorteks
I just picked up the Hot Racing 17mm hex adaptor which adds 10mm in offset. Does anyone know if I'll get body rub with a set of Badlands MX 2.8 (PRO1012510) tires? I'm also considering the Trencher LP's which are much narrower and shorter, or there is another version of the Badlands (PRO117310) which are also pretty narrow, but have a nobbier tread, I think they might be a SCT tire. I also would consider Lockups or Six Packs, but then I'd have to remove my hex converters. Or maybe even 1/8 buggy tires? I'm looking to use them strickly off road, I have a set of Hoons for asphalt. Thanks in advance
I have the Badland trenchers on my granite version 3 and it's the same chassis so I think you would be okay
The Vorteks body is wider than the Granite. Without the hex extenders MX28's will definitely rub. I don't have a Vorteks, so I can't say for sure if the hex extenders prevent this.
