Kraton Will Notorious V6 wheelie bar fit kraton V6?
Would the notorious v6 shocks fit the notorious v5??
Yes. No issues. Same shocks just 1300cst in the V6 & the V5 are 1000cst. Bolts right up & V6 shocks are EXB spec.
Can you explain the cst? Yes! I noticed they are now stock on the V6 which is sweet. Reason I asked is I have a typhon v5 motor esc tx rx and I wanted to get a notorious v5 roller slider and need shocks among others!
Any thought on the electronics capability going from buggy to truck?
1300cst is thicker than 1000cst(80w) and dampen the shock movement more. Compression & rebound. The motor, ESC, electronics, etc are all the same from a V5 Typhon & V5 Notorious so you're good. 50t spur & 12t pinion are stock on a Notorious.
Thank you so much! Now I can get everything! I can't wait to rip a notorious! I'm getting a slider so any thoughts on servo? Other then the typhon. I ordered a 35kg but I may want bigger like 45kg
You're welcome! I have a Notorious V5 also. Modded a little w/ bolt on's. 35kg is fine. 45kg would be plenty. A DS3235 servo is good but way to tall for a stock mount & requires more parts & mods. Dude I love my Notorious & it's a blast & probably my favorite RC!
One BIG must is check the center diff fluid, clean out & fill up with a minimum of 200k silicone fluid. Or it'll melt the composite diff case with appropriate Notorious bashing! Ask me how I know 🤣 For me- 500k center fluid was too thick & I made up some 375k & it's perfect.
