Yes it will fit, but you will need a 5mm bore pinion as the Mega has a 3.5mm bore.
It will fit either. The adjustable motor mount allows you to use a wider range of pinions and better set your mesh.Do i need the adjustable motormount to or does it fit stock motormount?
Yes they are compatible. The BLX version at one point was stronger as it was CNC cut vs the Mega was stamped. Not sure if that changed in V3 or not.Do you know if the 3s blx motormount fits typhon mega? Thanks
