2400kv 4068 you will need to change the esc connectors to 6.5mm though.You said the plastic stock diffs are rated for 4S? What would be a good motor to pair with the firmer 130 amp ESC?
For 4s? I believe a 2800kv n lower. I run a 2400 in a senton on 4sYou said the plastic stock diffs are rated for 4S? What would be a good motor to pair with the firmer 130 amp ESC?
YesJust picked up a Firma 130 amp ESC and wondering with a 4S battery if the differential, motor and other drive train components can handle the power?
Drive train yes but not motor..
I still run the stock 3200kv motor on 4s. I just make sure to go easy on the throttle and watch the temps. I also dropped it down to a 13t pinion.Yes
What is your motor rated for? If it's rated for 3 s I wouldn't worry but if it's rated for 2s then that's sketchyYes
