Big Rock Will the Kraton 4S V2 shocks fit the Big Rock correctly?
basher27
Looking to put these on my big rock anyone know if the sizes would match up? Thank you
SrC
RC is a lifestyle choice
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
They would technically bolt up.
Just that the height may be off as well as the spring rates. IDK. Not really plug and play to some extent making them work. IDK.
Compare the height spec dimensions of the stockers to these. To see where you would be.
Many rather go with Arrma 6s shocks. Mojave's or 6s Typhon ones. If I am correct
6s shocks are the better shocks hands down. Just need to select the correct size ones.
I know you can get the Alloy Red shock bodies as an option part by themselves. If you are more concerned about that look.
Alloy bodies may be smoother more Plush. I don't own a 4x4 to say either way.
Let others chime in. :unsure:
Below are the front and rear Option part shock bodies for the Big Rock.
https://www.arrma-rc.com/en/product/aluminum-shock-body-11x51mm-2/ARA330667.html
https://www.arrma-rc.com/en/product/aluminum-shock-body-11x58mm-2/ARA330668.html
Camaroboy383
Invention is the mother of necessity!
Hospitality Award
Connecticut
  1. 4x4-Mega
  2. Felony
  3. Outcast 4s
  4. Outcast 6s
  5. Outcast 8s
  6. Typhon 3s
  7. Typhon 6s
Short answer is no.. they are far to long, especially the rears.. They can be made shorter and will fit if you have some time to mess with them, and figure out a shorter spring set...
Then again, you will have to mess with any 6s shock as well, so pick your poison..
Hr v1 4s shock bodies, Typhon 6s shafts, 308 rod ends, and v1 outcast/kraton springs would be a direct replacement with proper length.. 👍
  1. Felony
  2. Kraton EXB
  3. Senton 3s
Actually if you just got the fronts, you should be only 10mm too tall on the front and the rear are the same length 111mm.. you could use your BR springs as well and that would soften them, I say got for it!! 😎
Camaroboy383
Hospitality Award
Connecticut
  1. 4x4-Mega
  2. Felony
  3. Outcast 4s
  4. Outcast 6s
  5. Outcast 8s
  6. Typhon 3s
  7. Typhon 6s
The 3s springs are a different diameter unfortunately... The new 4s springs are the same diameter as the 6s line..
Hawgwild1717
I have a senton and a new outcast 4s and I'll tell you those new shocks are worlds better than the senton ones. No chassis slap on the way I drive mine. Not huge jumps at the skatepark but I still like to party lol
