Yes but imo its just going to bend ur chassis Backwards
If you go with the T2T brace I would also get the chassis braces.Oh dang.
all the other EXB stuff bolts right up to V3?
thanks for the info.If you go with the T2T brace I would also get the chassis braces.
Yes all of the current and EXB parts can bolt onto the older models, V1 and V2 you will need to modify the chassis for the battery tray.
You must have a V2 Outcast as the V3 had the T2T brace and the newer roll hoop already, technically the EXB is the V4 of the Outcast. Outcast is 1 version behind everything else and Notorious is only on V2 or V3. Sorry it's a holiday weekend and I've been drinking so my CRS is kicking my butt.thanks for the info.
Already have Voltage Hobbies aluminum chassis braces.
outcast EXB 6S shocks are “EXB” too or same as rtr models?
Also, won’t I need the newer style roll hoop too, to fit the T2T brace?
Ok cool figured I could just cut it and squeeze it through.You must have a V2 Outcast as the V3 had the T2T brace and the newer roll hoop already, technically the EXB is the V4 of the Outcast. Outcast is 1 version behind everything else and Notorious is only on V2 or V3. Sorry it's a holiday weekend and I've been drinking so my CRS is kicking my butt.
The current shocks are a little different from the previous versions but jot enough to make any difference. You don't need the new roll hoop, you can cut the center of the old one out and the T2T brace will go through.
What year is it and what radio? If it has the TTX300 it's a V2 V3 had STX2. There never was a V4 of the Outcast as I mentioned above the EXB is technically the V4.Ok cool figured I could just cut it and squeeze it through.
nope, def have a V3, i verified the model number on the chassis and on the box.
and thanks about the shocks, ordered metal ends and new boots instead of upgrading.
