- Dundee Michigan
- Infraction
- Kraton 6s
- Notorious
- Talion
- Typhon 6s
- Thread starter
- #41
Guy esc keeps cutting out. U think this is all the stock esc can handle or is something wrong with set up?
Yep it’s really hard to keep that stock ESC from amp limiting. Theoretically you can make a 1/2 mile or more pass and slowly add throttle. But that is not realistic. Most passes are 1/4 mile or less. Even then you only get to full throttle 3/4 of the way thru the pass. If you are just jabbing the throttle quickly, that is a big part of it. You may even get higher speeds never getting to full throttle at all. Slowly and smoothly getting to 1/2 or 3/4 throttle might be the best you can do.
Yea I was easing in to the throttle and right after I hit full it would cut out. U think the stock 160amp would do a little better?Yep it’s really hard to keep that stock ESC from amp limiting. Theoretically you can make a 1/2 mile or more pass and slowly add throttle. But that is not realistic. Most passes are 1/4 mile or less. Even then you only get to full throttle 3/4 of the way thru the pass. If you are just jabbing the throttle quickly, that is a big part of it. You may even get higher speeds never getting to full throttle at all. Slowly and smoothly getting to 1/2 or 3/4 throttle might be the best you can do.
Not really much better. Try staying out of full throttle or grab a Castle ESCYea I was easing in to the throttle and right after I hit full it would cut out. U think the stock 160amp would do a little better?
You know I got a heavy finger . But I'll will get a castle after Christmas. Don't want piss my ol lady off.Not really much better. Try staying out of full throttle or grab a Castle ESC
