Outcast Wing Mount for Wingless Outcasts
tobyjoe
NJ/NYC
assuming one wanted to remove their rear wing and wheelie bar, is there an aftermarket or Arrma part that fills the role of the wing mounts on the lower end?
Do folks just cut down the plastic parts?
I'm trying to tighten up the shape of my outcast for tighter technical tricks.
Cutting down the parts is going to be the easiest. You can order the body mount set for the Senton. Tower is currently on back order.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEPDG&P=ML
I ditch the wing, but made a small block out of 1/2" TPR so there was something there to hit the ground before the rear tower. I did the same on my ERBEv2, but had ordered some black TPR by then.
I round the edges so they are less likely to dig into the ground, then they slide easier while still adding a "bumper".
