Getting this build thread started, I'll edit it along the way with more and more upgrades. Because let's be honest.. the upgrades never stop!
Kraton EXB newest batch with fixed diff shims Jan 2021
Electronics:
Hobbywing Max6 160amp ESC w/powerhobby Fan
Hobbywing 4985SL 1650kv motor
Powerhobby twin fan heatsink w/alluminium rocket fans
6s with Tekno pinion 18t bashing and 20t for speed, stock spur gear
EC5 connectors, IC5 on ESC (easier to solder male connector)
JX 46kg HV servo
Radiolink RC6gs transmitter R7FG receiver (gyro on)
Zeee 3s 5200mah 50c batteries x4
Goldbat 3s 5200mah 80c batteries x2
Diffs:
Front open, center LSD max effect, rear open
20k/300k/10k
Shocks:
Factory Front- factory 80w, Rear- factory 80w
M2C shock bushings
Parts:
DBoots Backflip MT tires vented
Pro-Line Brute White Body
PPS center diff mount
PPS center diff bearing mount
EXB shock stand offs (why was this only EXB part not factory?)
RPM rear skid plate
Outcast side guards
Outcast wheelie bar
Hot Racing swaybar covers
Hot Racing servo saver and bell crank w/bearings
Hot Racing front ball cup nuts with derlen bushings
M2C rear shock tower support brace
Hot Racing servo horn and arm
RPM wing mounts (not installed yet)
M2C 5mm offset hex adapters
Electronics:
JX 46kg HV servo
Diffs:
20k/300k/10k
Shocks:
M2C shock bushings
Parts:
RPM rear skid plate
Outcast side guards
Outcast wheelie bar
